I would if I could … but I can’t. So I’ll guess that it’s 3/16”. Did I get close? The structure is 2” to 6” out of level. The concern is damage that will occur when lifting the right side. Apparently the out of level condition has been there for over 22 years.Solve for x.
No, closer to 1/8"I would if I could … but I can’t. So I’ll guess that it’s 3/16”. Did I get close? The structure is 2” to 6” out of level. The concern is damage that will occur when lifting the right side. Apparently the out of level condition has been there for over 22 years.
Should that be .13”?.013" down on the left side if the right side goes up 1".
If you lift the left side 1" the right side will raise up 7.67"
If you lift the left side, won't the right side go down?If you lift the left side 1" the right side will raise up 7.67"
Yes, that is what I meant.If you lift the left side, won't the right side go down?
