So I'm on a second floor of a B use group, and my occupant load is less than 29 on the 2nd floor. The building is fully sprinklered, and I'm allowed to go up to 100 feet for my common path of egress ((per IBC 2018 1006.3.3 (2). There's only one fire rated stair case going from the 2nd floor to the first floor as part of my egress path. My question is, do I have to add the distance traveled within the stair case as part of the common path of egress before we have the option to go in two ways to the other exits on the first floor? For some reason, I feel I've seen somewhere in the code that you can stop calculating the distance at the stair door (at the top level) if the stair enclosure is fire rated, or is only my dream ?
