Hello all,
I am trying to get technical clarity on this subject without emotional opinions.. I have called my local building dept, the ICC and posted on another forum and can get a consensus.
I read this older post from this website
of treated for ease or ordering, availability and strength..
Anyway,, using engineered or framing lumber and adhering 6" butyl rubber would simplify things on a few levels,, Vycor says yes, has a drawing with no data, My local dept say is is OK with no data, ICC has no answer, Dupont has no advice. In the above link some contractors say they have been using Vycor/Grace for years.
Also,,,,, If greater than 8 inches above ground contact no treatment is needed??????
Thanks in advance.
Chris
R317.1Location required.
Protection of wood and wood-based products from decay shall be provided in the following locations by the use of naturally durable wood or wood that is preservative-treated in accordance with AWPA U1.- Wood framing members, including columns, that rest directly on concrete or masonry exterior foundation walls and are less than 8 inches (203 mm) from the exposed ground.
Thanks in advance.
Chris
