I was thinking the configuration you show might actually be acceptable because A117.1 606.2 does not say the clear floor space has to be centered on the lavatory. Maybe it does say that somewhere, if it does I missed it. Here are a few provisions regarding centering of a clear floor space and one regarding offsetting the clearance:Acceptable or not?
I was thinking the clear floor space could be shifted even more if necessary just as long as the point of water delivery and means of activating water flow (in this case the motion detector) were within the 30”x48” clear floor area.(Barely) acceptable, but not good, as long as the trash can doesn't protrude beyond the edge of the lav.
Thank you, I looked several times and couldn’t find anything.I don't see a requirement for the clear floor space to be centered on the lav.
You could be right, it does look close.Is the paper towel dispenser missing the general reach of maximum 48" off the FF?
My understanding of how cane detection works is that as long as the bottom edge of an element is 27” maximum above the floor it can project any amount. If the bottom of the trash receptacle was at 28” it would be limited to the 4” projection unless a separate detectable edge were installed below it.Shouldn't the trash receptacle be 27-inches off the FF for a cane detection and not beyond 4-inches from the wall?
Thanks for sharing this, I was wondering what they might have showed on the plan, my prediction was that they did not show a projecting trash receptacle, I was not expecting that they would leave it off the plan all together.Here is what was submitted:
If you’re getting something that close to 42” then that’s probably what they were intending. The top of the door is visible in the mirror and there’s no closer on the door. I guess if the designer can demonstrate that any door maneuvering clearance will work then that’s OK.The distance from the front of the lav to the wall with the door is about 41". The only door approach that comes close to working is the Latch Approach, Push Side without a door closer. Minimum space required is 42" off the wall, extending 24" beyond the door latch side.
Moving the trash receptacle would resolve any clearance issue at the lavatory. Personally I wouldn’t gripe if I had to take a few steps to dry my hands. I could then use the paper towel to open the door and push it open then conveniently throw it in the trash next to the door.There may be sufficient space to mount the waste receptacle in front of the toilet, same wall as the door.
That space is taken with the infant changing table.There may be sufficient space to mount the waste receptacle in front of the toilet, same wall as the door.
Florida does not require vertical grab rails. They removed that from the ANSI A117.7 that they use and moved all scoping from the IBC Ch 11 to the beginning of the Accessibility book. This was a learning curve for me as I was accustomed to no changes in the A117.1 where I came from.Plan does not show the vertical handrail at the side wall beside the toilet, I’d check the interior elevation to see if it’s shown there and make sure all the dimensions to all grab bars are correct
More of an FYI -Here is what was submitted:
There may be a concern or two about a baby changing station there.That space is taken with the infant changing table.
You must also provide knee and toe clearance for a forward approach; thus, a 27-inch clearance is required under the table.
Thank you for the clarification.Florida does not require vertical grab rails.
Jeff
What code are you using?
IBC CH 11?
ANSI 117?
CA?
FL?
TX?
Which code or standard are you asking about?2023 Florida Building Code, Accessibility, Eighth Edition
ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.codes.iccsafe.org
Mark, you asked me what code we are using and I gave you the link to the code we are using. I am a little confused which can be normal.Which code or standard are you asking about?
