3Darchitect
I'm in the process of revising most/all drafting standards in my firm and want to critically think about all aspects of the set to see if there's a different/better way of doing things. I realize that in a lot of cases, the answer is simply up to the firm and there is no right/wrong/better/worse solution.
My question here is about accessibility or typical construction diagrams. Most sets have some sort of general diagrams for mounting heights, clearances, etc. I'm wondering if anyone has ever seen a set reference external sources IN LIEU of drafting the diagram itself. This would ONLY apply to a construction constraint that has a diagram within the source material, and therefore would most often deal with Accessibility diagrams and some IBC diagrams (think door clearances).
The reason I'm considering this is because upon looking at my firm's previous sets, a number of these diagrams (which had been drafted a long time ago) were now inaccurate or weren't correct to begin with. My intent would be to provide clear references in the form of naming the code + section, and also a live link to a free internet source. This link would of course, only be valid when viewing the plans in digital format.
PROS:
- Limits liability on the firm/architect for potentially incorrect construction standards
- Limits the need to periodically QAQC these standard diagrams, mainly when known code changes happen
- Live/digital links provides the opportunity to reference other non-code (but reliable) sources for supplemental information - yes, this would be a form of liability as well though
CONS:
- Forces the GC/consultant outside of the set to an external source which may reduce the chances of them looking at the content at all (I've always questioned whether or not this should be a concern of the architect)
- While a lot of GC's are starting to have tablets and digital access on site, I realize that a lot of the trades still work off physically printed sets
Feel free to tell me if I'm completely off my rocker on this one too
PROS:
CONS:
