I’ll give it until they attempt to remove the forms.I'll give it ten years before the tips of the roof overhang start to break off.
Especially since this house is right on the ocean in south Florida with hot, humid air coming in. This will be interesting.I'll give it ten years before the tips of the roof overhang start to break off.
Radiant floor tubing?Please explain what "temperature" reinforcement is. In 30 years I have never seen a set of plans that used that term for reinforcement.
Reinforcement against stresses induced by expansion/contraction due to temperature changes. I gather the excerpt is for a roof slab, so the temperature variation on the upper surface of it will be greater a slab would see from earth contact or from exposure to conditioned space.Please explain what "temperature" reinforcement is. In 30 years I have never seen a set of plans that used that term for reinforcement.
Si........Building the formwork is going to be very interesting.
I think you mean 1/4" off the center of the slanted wall. As a composite material, the neutral axis in bending may not lie at the center of the cross section.I think it's curious that the slanted concrete wall is only 4 inches thick. The rebars are #4 (1/2") in each direction, so that's a total of one inch. Assuming that the rebar should have a minimum of 1-1/2" of cover, that leaves essentially zero leeway for where in the wall the steel gets placed. That means the vertical bars' axis will be located just 1/4-inch off the neutral axis of the slanted wall.
Cheers, Wayne
That makes sense for low flexural demand where the concrete is uncracked and can act in tension. As then the cross-section is almost symmetric.Correct. But with the longitudinal steel so close to the centerline of the wall, the neutral axis can't be very far from the centerline.
