Builder Bob
My comment is based off the original post. "Permanent" provisions for cooking.
Even a stove is not permanent, whenever a remodel occurs, chances are the "appliance" is replaced - so in theory (at least) all appliances are temporary as built in range tops, built in wall ovens etc. are deigned to be removed if necessary for replacement. The only thing that will remain is the point of utility utilization (gas or electric)
If a hood is used, components and the hood may be replaced - but generally the duct work remains unless reconfigured.
If it is a wood burning stove - same concept, the chimney or flue will remain.
Sometimes, I think we may be our own worst enemy whenever we over analyze and fail to let common sense dictate a peaceful harmony between code language and the code intent.
This is a perfect case where permanent provisions are required but even appliances are not permanent. Common sense would dictate utility provisions and any other provisions that may be required such as chimney, mechanical exhaust, etc. are sufficient to indicate the intent for permanent provisions has been made.
