    Dismiss Notice
What are permanent provisions for cooking?
Discussion in 'Code Administration' started by jar546, Jan 9, 2020.
  1. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    857
    328
    I understand... I am providing a rebuttal argument that the provision required can be the energy source for the intended appliance and that the appliance can be the responsibility of the occupant.
    In concept, this is similar to provisions for sleeping. A bed is not a requirement; it would be up to the occupant to install their desired furniture for sleeping (bed, cot, hammock, etc.).
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,871
    992
    X2....I know NFPA does not consider a microwave "cooking"...
    jar546 likes this.
  3. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    4,128
    394
    Northern CA city building code.
  4. TheCommish
    TheCommish Sawhorse
    Sep 27, 2011
    899
    152
    Seem like Permanent cooking is like defining obscenity and pornography
    In the summer of 1973, the Supreme Court decided a group of pornography/obscenity cases that set the standards for the future of pornography. In his Dissent in one of these cases, Justice Brennan wearily admitted:
    "Our experience since Roth requires us not only to abandon the effort to pick out obscene materials on a case-by-case basis, but also to reconsider a fundamental postulate of Roth: that there exists a definable class of sexually oriented expression that may be suppressed by the Federal and State Governments. Assuming that such a class of expression does in fact exist, I am forced to conclude that the concept of 'obscenity' cannot be defined with sufficient specificity and clarity to provide fair notice to persons who create and distribute sexually oriented materials, to prevent substantial erosion of protected speech as a byproduct of the attempt to suppress unprotected speech, and to avoid very costly institutional harms."
    source linked here
  5. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    2,278
    350
    Even a stove is not permanent, whenever a remodel occurs, chances are the "appliance" is replaced - so in theory (at least) all appliances are temporary as built in range tops, built in wall ovens etc. are deigned to be removed if necessary for replacement. The only thing that will remain is the point of utility utilization (gas or electric)
    If a hood is used, components and the hood may be replaced - but generally the duct work remains unless reconfigured.
    If it is a wood burning stove - same concept, the chimney or flue will remain.
    Sometimes, I think we may be our own worst enemy whenever we over analyze and fail to let common sense dictate a peaceful harmony between code language and the code intent.
    This is a perfect case where permanent provisions are required but even appliances are not permanent. Common sense would dictate utility provisions and any other provisions that may be required such as chimney, mechanical exhaust, etc. are sufficient to indicate the intent for permanent provisions has been made.
  6. TheCommish
    TheCommish Sawhorse
    Sep 27, 2011
    899
    152
    NFPA staff answer to what is cooking
    The final determination on what is considered facilities for cooking will rest with your AHJ. However, in NFPA 101 cooking facilities generally applies to equipment used for the cooking of food and equipment that generates heat is connected to electricity or a fuel source (e.g. stove, oven, hot plates). Generally, an area with equipment solely for reheating food (i.e. microwave) would not be considered a cooking facility.
  7. Sleepy
    Sleepy Registered User
    Jan 6, 2017
    100
    48
    Fair enough, but NFPA is looking at it from a fire hazard point of view. The Building Code or an AHJ might look at it differently, depending on the goal and language of the particular paragraph.
  8. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,481
    825
    Not even walls are permanent. But you cannot not take the words in the code to the Extreme.
    I do not know where the verbiage "permanent" is used in the building code to define an ADU or guest room.
  9. jar546
    jar546 *****istrator
    7,419
    605
    I want to see where the word "provisions" means a receptacle for a stove. I would not agree.
  10. TheCommish
    TheCommish Sawhorse
    Sep 27, 2011
    899
    152
    NFPA 5000 a building code that uses similar language, so I would opine that is it no just fire safety
  11. ICE
    ICE Sawhorse
    8,636
    995
    So what would you agree with? The "Dwelling Unit" definition requires context before a limit on what would be required can be determined. If it is a house, then hookups, gas or electric for a stove along with space for the appliance. If it is an apartment for rent I would expect there to be a stove installed along with a refrigerator and cable TV.
    Here in CA. there is a recent permutation of a dwelling unit referred to as a Junior ADU. It has a defined cooking provision. Gas is not allowed and the electrical supply is limited to 120 volts. That sounds like a hot plate, rice cooker and for the upwardly mobile, a microwave. (with convection of course)
  12. jar546
    7,419
    605
    Provisions for cooking means appliances installed, not just receptacles. I could plug a welder into a 240v stove receptacle.
  13. ICE
    ICE Sawhorse
    8,636
    995
    You could put a stove in most laundry rooms ... gas or electric ... but would you?
Share This Page
