I was going to say drops.....Scrap, if tied in place column details
IF that was the intent, most plans I have seen have called them hairpins or as you say, just corner reinforcement, usually seen on PT slabs and at columns, but same principal I imagine.There is no real name, but you can call it "corner reinforcement."
This is to prevent re-entrant corner cracking. They are used when contraction joints are not provided at the corners. Here's the PowerPoint slide from my Building Construction Technology course I used to teach:
My answer is the same. In PA, they were called 'hairpins'most plans I have seen have called them hairpins or as you say
We call the thrust rebar at a PEMB "column" base hairpins but never heard it for the corner bars...My answer is the same. In PA, they were called 'hairpins'
