You bring your own?Not required......
Not in any commentary as far as I've seen. I've had clients get called out for this by CASps (Certified Access Specialists - a CA specific thing) in the past. I asked a CASp about this and they said it's something that could create a barrier. Since the shelving is movable (often on casters), it could be moved to a position that impedes someone in a wheel chair from easily getting to the toilet. If the casters lock (which some of those shelving units do) or if the unit has no casters, then you've effectively created a barrier.Where do you get this? Does it say this in the commentary? I don't see the difference if this same shelfing was hung on the wall at the same place. Seems to me the toilet would be more accessible if the shelfs were movable rather that attached to the wall at that spot.
A shopping cart has wheels so we should probably not allow those as they could end up in the bathroom and would Shirley be a barrier....Not in any commentary as far as I've seen. I've had clients get called out for this by CASps (Certified Access Specialists - a CA specific thing) in the past. I asked a CASp about this and they said it's something that could create a barrier. Since the shelving is movable (often on casters), it could be moved to a position that impedes someone in a wheel chair from easily getting to the toilet. If the casters lock (which some of those shelving units do) or if the unit has no casters, then you've effectively created a barrier.
Is that why some stores have signage requesting patrons not to take merchandise into the toilet rooms?A shopping cart has wheels so we should probably not allow those as they could end up in the bathroom and would Shirley be a barrier....
First, yes, that would technically be a barrier. But realistically, there probably wouldn't be a lawsuit if someone took a shopping cart into a restroom and left it there. there'd be a lot of confusion / security would get involved, but the tenant / owner isn't going to get sued for that (I hope).A shopping cart has wheels so we should probably not allow those as they could end up in the bathroom and would Shirley be a barrier....
I disagree, but I think we'll never agree on that unless someone posts some commentary or court case on it lol. I just like to play things simple and safe. If something could be a barrier, then within reason it should be removed or mitigated. If a shelf could be put directly in front of a toilet and locked in place, and unlocking it would cause a violation of some other section of code, then it should be positioned outside of the maneuvering clearance.I just hate when people enforce what "could" happen....So I over dramatize it for attention...And if the shelving is allowed, it doesn't matter if it is on wheels or not...
I usually just poop on the floor if there is something in the way...I disagree, but I think we'll never agree on that unless someone posts some commentary or court case on it lol. I just like to play things simple and safe. If something could be a barrier, then within reason it should be removed or mitigated. If a shelf could be put directly in front of a toilet and locked in place, and unlocking it would cause a violation of some other section of code, then it should be positioned outside of the maneuvering clearance.
What a tenant or owner does after I leave is of no concern to me. I told them what I believe they need to do. If they move the fixture to get my signoff then move the back to where it was after I leave, then they take on that responsibility and potential liability. That's on them.
That reminds me of the time I had a football coach ask if got paid by the flag....You inspectors have nothing better to do than make up codes for stuff like this. It's all about the money.
This is another good example of how much more restrictive CA codes are. We have:And the commentary is non-specific on fixed or moveable...
❖ The water closet clearance can overlap elements of the accessible route (path of travel, door clearance) including the turning space required in the toilet room [see Section 301.2 and Commentary Figures C604.3.3, C603.2(a) and C603.2(b)].
Items that can overlap the clear floor space of the water closet without blocking access to the water closet include grab bars and the tissue dispenser. Items that cannot overlap the clear floor space for the water closet include counters or the accessible lavatory. Because there is an assumption that only one person will be using the toilet-room facilities at a time, the spaces at other fixtures where the person who uses a wheelchair would sit to use those fixtures may overlap the clear floor space at the water closet [see Commentary Figures C604.3.3, C603.2(a) and C603.2(b)].
Other items listed, such as paper dispensers, sanitary napkin receptacles, coat hooks and shelves, are items commonly found in toilet rooms or toilet stalls. Other items that also are often found in the bathroom are seat-cover dispensers and fold-up diaper changing tables. It is not the intent of this section to prohibit these items within the toilet room or stall, but rather to make sure that these items are located so that they do not block access to the water closet within the room or stall.
For diaper changing stations see Section 603.5. The requirements are the same regardless if the diaper changing station is in the accessible stall or within the room.
Is the turn around space provided? The room looks tight.
If the International Plumbing Code is applicable, I see a violation with that, too.
Well, that would require us to open a code book, and we all know when it comes to accessibility, the book might as well not exist until we're called out or a client gets sued. Not a joke btw. I know architects with that mindset.Come on, architects -- get a clue.
I did this exercise a few years ago. The numbers I came up with using CA code (I think ICC A117.1 allows for slightly smaller) is 7'-4" x 6'-6" with an outswing door and 7'-4" x 7'-3" for an inswing door. I could probably reduce one or two of of these dimensions a bit if I used a different fixture or rearranged the room a bit, but for a "standard" layout (lav and WC on the same wall), these are some of the smallest dimensions I've come up with so far.Years ago I plugged all the requirements and turning spaces into an AutoCAD drawing and then drew a toilet room around everything.
But for the WC they are specifically allowed....That is the rub...someone needs to fix ANSI...I have always believed that we need to view things that don't appear to be addressed explicitly through the eyes of the end user. In the case of a single-occupant toilet room, consider that you're the person in a wheelchair who is trying to use the facility. If you've got a fancy knick-knack shelf and a trash receptacle in the maneuvering space for the water closet and/or door -- it doesn't really matter that the items aren't bolted down.
Once i checked a toilet room during the drywall inspection and it complied. At the final inspection they had tiled the toilet room, and it did not comply anymore.I tell people 7'1" on the wet wall is absolute min. but you better have thin wall finishes and don't miss....With alternative design you can get it smaller...
