Inspector Gadget
CORRECTION:
I was completely wrong.
Ah, yes, the bonding refrain of the average married man.
CORRECTION:
Everyone.....Everyone gets a violation notice....So who gets the correction notice? The electrician or the HVAC contractor. Maybe the design professional should pay for the correction if they are installed per plans.
There will be a boatload of corrections. How will the units perform while pulling hot air from one unit to the next?Everyone.....Everyone gets a violation notice....
Assuming there is one...Maybe the design professional should pay for the correction if they are installed per plans.
You probably can't get them in Cali....Only the people are allowed to be plastic...A little bondo, a little paint … good as new.
Maybe they shouldn’t sell compliant plastic gas cans … ?
Plastic is the most ubiquitous manmade substance in the universe.Only the people are allowed to be plastic
If you squint, the word rectal pops out.I'm half-tempted to print this and take it to the pharmacy.... just to see what I'd get.
The good news is it might not be that hard to get a header under the truss bearings....
Engineered element, not installed per engineer's instructions.There would be no appreciable load on the truss intended bearing point had it landed over the wall. A 3/4" plywood gusset screwed and glued would be a reasonable fix. The gusset should commence at the end of the truss and extend 24" past the wall. If you're a nervous sort, use 1" thick plywood.
