steveray
I opened it just fine. looks to me that you have some significant interior exiting and RR accessibility issues to work thru.
3 story open stair too?
do i have a problem with that?3 story open stair too?
he is saying that because its not a means of egress its not a problem, we have 2 means egress on each floor with out the stairs, the Elevator and a direct exit to the street on each floorI would suggest you have the architect that is going to sign these plans take a look
check again there is an elevatorMany RR's are not compliant (>6 fixtures ambulatory and accessible stalls req'd.), bldg lacks an elevator?
the elevator door is outside the buildingHow is an elevator a direct exit to the street? each floor must have two (2) exits to the public way, no?
cab is large enough for a WC but not for a gurney, my understanding is we don't need it to be accessible for a gurney , do you know otherwise?Elevator on emergency power? Cab large enough for a gurney or WC?
He needs to look harderhe is saying that because its not a means of egress its not a problem, we have 2 means egress on each floor with out the stairs, the Elevator and a direct exit to the street on each floor
Mr. Blum, if i understand (I don't) it is ok in NY to hide the accessible entrance (an elevator) to the rear (back of the bus)?
fully agreeSo wrong JP, accessible primary entrance should be readily visible and not require going to the "back of the bus".
In this case the elevator could have/ should have been located at the front of the building.
