tbz
Silver Member
Designing (3) gates for around a resident swimming pool in a student housing location. Pool sits between 2 buildings. The barriers are being installed for separation, the question comes to the locks for the gates.
The need to meet ADA, I would prefer not to install regular every day lever locks. The unit I am looking at says it is ADA compliant, but is a push button activated lock complaint with ADA & is it also allowed for MOE egress on the gates for exiting?
This is the lock I am thinking of using I will also put the weblink after the video.
Weblink to the product: Being this is outside I was trying to keep it relatively non metallic.
As to the installation, the pool needs to be locked when closed, but the interior still needs to be able to exit. Also, my understanding is the lock can not be up at 54" because of ADA, thus the entire area needs to have screen protection from all angles with mesh less than 1/2" in openings within 18" of the edges of the lock, is this correct?
