Where could the water come from without enough pressure to climb out of a cleanout?
ICE, have you determined the water source? Is there a swimming pool in the area? Neighboring property issue?
I haven't heard from the contractor. I wrote a correction asking them to determine where the water was coming from and stop the flow. I also stated that a camera run is not any good with water running so another inspection with the camera will be required. I passed by there today and took this picture. Apparently they know something that I don't..ICE, have you determined the water source? Is there a swimming pool in the area? Neighboring property issue?
Commercial properties generally have a check valve on the potable water system and therefor the expansion tank is required.
Now and then a homeowner will ask me if the code really requires the expansion tank.
No. Never in a pan and between 6” to 20” above grade .....outside.Would you allow that copper discharge pipe to be that close to the FF? 6-inch rule?
The job is an electrical service upgrade and this is the service entrance conduit. Sun glare prevented me from seeing clearly. It appears as though there is no roof jack. So I wrote a correction to install a roof jack. Shirley seeing clearly in a picture makes a difference.
So now the correction will change to “install the roof jack correctly”.
t
CDA:
We already have it, the top two candidates from today's election will that appear on the November election ballot. You're right, it is a disaster, a few of the candidates propose getting rid of it if they are elected. The big proposition here was a proposal to require a vote to premit virtually any new building, the city is on the right side here and put a competing measure on the ballot so votes on permits would only occur if someone proposed permiting a building on designated open space or parks. Lots of the measures are as confusing as building codes, yes becomes no. For instance, the state is raking in a fortune in these carbon credits, a proposition portends to limit that money to transportation, in reality it sends it to bicycle trails, the governor's stupid train to nowhere, and more new BART cars, the reality is that they have removed most seating from the new cars to make room for more bicycles and wheelchairs with only a couple of seats in each car.
