More like a pond. LOL!Market it as a lakefront property.
First inspection for a rewire and a service panel upgrade. There was no AFCI protection. Licensed electrical contractor.
At a subsequent inspection the AFCI has been installed. The service panel was okay at that point but there was no access to the dwelling to inspect what went on with the rewire.
It is now a month later and there is access to the inside. The AFCI protection has been removed.
The contractor stated that the refrigerator and garbage disposal were tripping the AFCI breaker so he replaced the AFCI breakers with standard breakers. I made myself clear as to what I think of him.
While I think AFCI's unlike GFCI's are snake oil, code is code & they need to be be there, also heard of removing the rebar after the inspection but before the pour, that one would be a bit harder to catch, unless they were caught in the act, as they should. That would be a expensive thing to fix.I have seen houses that had the arc faults taken out after the final inspection to be used on a different job. I also seen the same thing with the accessible exit signs with braille.
I only saw this when the arc-faults have been removed when another permit has been issued for the same house and I don't have any way to make them put the arc-faults back. No permit is required to replace breakers.While I think AFCI's unlike GFCI's are snake oil, code is code & they need to be be there, also heard of removing the rebar after the inspection but before the pour, that one would be a bit harder to catch, unless they were caught in the act, as they should. That would be a expensive thing to fix.
If I have approved a service panel upgrade that held AFCI breakers and then I encounter the same service panel upgrade with the AFCI breakers replaced with standard breakers....the fat lady is signing her heart out.I only saw this when the arc-faults have been removed when another permit has been issued for the same house and I don't have any way to make them put the arc-faults back. No permit is required to replace breakers.
Haven't you heard of celebrating Christmas in July?!?!? ;-)This was in video that I received for smoke and CO alarms. On 6-24-21 View attachment 8019
