Yep, this qualifies as requiring attic access. I was asked the "Why?" question and other than because it is required, I really did not know the true reason, only my thoughts.
Once again George, you are getting personal with me and I find your comment unacceptable. Last warning.GHRoberts said:Furring strips from the rafters to the studs. About 29" off the floor. No access needed.So you are going to require access because the guy does not put in a few furring strips? You really need to get a life.
Simply divide the space to less than 30 sq ft since to be and attic it requires both height and space.Pcinspector1 said:Required 807.1 Height over 30" and over 30sf...........pc1
Simply provide an attic accessFredK said:Simply divide the space to less than 30 sq ft since to be and attic it requires both height and space.
Would not be a problem with spinklers.......High Desert said:Being the devil's advocate, once you require an attic access in these types of spaces you just open the door for storage. Let's pack the otherwise empty space with an increased fuel load.
It is his housesteveray said:Mark....you always have a great picture for every subject....where do you find them?
mtlogcabinmtlogcabin said:It is his house![]()
It's required so that the grow lights are accessible.jar546 said:Yep, this qualifies as requiring attic access. I was asked the "Why?" question and other than because it is required, I really did not know the true reason, only my thoughts.
