Okay I may need to back track a bit here. According to the original posting the height from the top of the ceiling framing is 24" (<30"). However he also states that the code requires the 30" measurment to be taken from the bottom of the ceiling framing members. Depending on the size of the ceiling framing memebers the measurement may be 30" or >. If so, an attic access may be required. If that is the case and an attic access is required, it needs to be placed in a readily accessible location. Inside a 2' deep closet doesn't qualify. If it was a walk-in closet and I could still get the required height above the access opening, I would accept it.
