Bathroom Floor Drain
You might ask them to bed the pipe in sand instead of rocks.
Is that required??
The State took plumbing away from us lowly Municipal inspectors, so I really don't care, I'm just curious. I've never seen under-slab plumbing bedded in anything but CA6 around here.
314.4 Excavations. Excavations shall be completely backfilledas soon after inspection as practicable. Precaution shall be taken
to ensure compactness of backfill around piping without damage
to such piping. Trenches shall be backfilled in thin layers
to 12 inches (305 mm) above the top of the piping with clean
earth, which shall not contain stones, boulders, cinderfill,
frozen earth, construction debris, or other materials that will
damage or break the piping or cause corrosive action. Mechanical
devices such as bulldozers, graders, etc., shall be permitted
to then be used to complete backfill to grade. Fill shall be
properly compacted. Precautions shall be taken to ensure permanent
stability for pipe laid in filled or made ground.
I suppose one could argue that this applies only to the back-fill. I think that the material that the pipe rests on is also required to be free of stones, boulders, etc. Sand works the best for easy compaction.
What is CA6?
2014 California Plumbing Code based on the 2012 Uniform Plumbing Code
Hmm, nifty. Wonder what the rationale is for that requirement? Does that section apply to all under-slab piping?
How different are the UPC and IPC?
What is CA6?
[h=1]Ca6 Stone[/h] CA6 Stone - Click to Zoom
This combination of 3/4 limestone and limestone fines is most commonly used to provide a base for paver patios, sidewalks and driveways.
Hmm, nifty. Wonder what the rationale is for that requirement? Does that section apply to all under-slab piping?How different are the UPC and IPC?
Well it is plastic pipe. As to whether it applies to under-slab locations, I say yes. Trenches for waste pipe get compacted.
I don't know what differences there are between the UPC and IPC.
What say thee oh plumbing inspectors?
Foolish and he obviously didn't think. He could have used a double wye (where that 3x3x3 wye is), buried the trap, and come back around to connect into the double though a 2 x 3 bushing.
