Forum Coordinator
What say thee oh plumbing inspectors?
Good one! FunnyI assume you are talking about the G-clef trap?
I was going to call it a Q trap and then I realized I hadn't used "G clef" since grade school music class...Good one! Funny
Is that required??You might ask them to bed the pipe in sand instead of rocks.
I suppose one could argue that this applies only to the back-fill. I think that the material that the pipe rests on is also required to be free of stones, boulders, etc. Sand works the best for easy compaction.314.4 Excavations. Excavations shall be completely backfilledas soon after inspection as practicable. Precaution shall be taken
to ensure compactness of backfill around piping without damage
to such piping. Trenches shall be backfilled in thin layers
to 12 inches (305 mm) above the top of the piping with clean
earth, which shall not contain stones, boulders, cinderfill,
frozen earth, construction debris, or other materials that will
damage or break the piping or cause corrosive action. Mechanical
devices such as bulldozers, graders, etc., shall be permitted
to then be used to complete backfill to grade. Fill shall be
properly compacted. Precautions shall be taken to ensure permanent
stability for pipe laid in filled or made ground.
Well it is plastic pipe. As to whether it applies to under-slab locations, I say yes. Trenches for waste pipe get compacted.Hmm, nifty. Wonder what the rationale is for that requirement? Does that section apply to all under-slab piping?How different are the UPC and IPC?
Foolish and he obviously didn't think. He could have used a double wye (where that 3x3x3 wye is), buried the trap, and come back around to connect into the double though a 2 x 3 bushing.What say thee oh plumbing inspectors?
