I can build them all for $110-$150 a piece depending which truss I will build as lumber just came way down but yet the Truss Plants have not reflected the drop because they want to pawn their overpriced lumber off on the consumer. They are charging me $333 a truss. Even if it ends up being more then what I calculated and ends up everything shoots up I am still saving 6k in a couple weeks worth of work. Thats 3k a week. After taxes at work i only take home after taxes 3k a week and have to be away from my family to do that.
I can lift them I did it in the past with 2x6 trusses on same width (uninspected) house I built but it was single story you couldnt do it two story. You flip them upside down, get one side up, flip it on its side, slide it over with one guy holding the other end, the other guy lifts up on other wall, you lide it over, then one guy gets in the middle to hold it while other guy blocks. It wouldnt work on a wider home then I am building but it will work on my place.
I am reading through code Its a little convoluted. My inspector said they had to be engineered, but as i mentioned in previous message "engineering" is loose word. We have engineers at this Mine I work at that design blast patterns, none of which are actually licensed in this state.
This article says this and I am trying to verify if its wrong. Spenard Builders Supply said the trusses are not required to have a stamp. They already provided me with all the specs
People on here I much appreciate their advice but can someone call out this article and say its wrong Note that under the IRC, both the residence and the wood Truss design could be performed by persons who are not Registered Design Professionals. There may be times when the Building Official will require the Truss Design Drawings to be prepared and stamped by a Registered Design Professional even though the structure was not. The key to this IRC provision is that if the jurisdiction requires the Construction Documents to be prepared by a Registered Design Professional, then the Truss Design Drawings shall also be prepared by a Registered Design Professional.
https://www.structuremag.org/?p=14283
