Code Quaffer
I am curious if anyone has done a deep-dive into C900 as Water Service Pipe?
If I look at the 2012, 15, and 18 IPC, as per table 605.3, the only allowable PVC must meet the following standards:
Polyvinyl chloride (PVC) plastic pipe ASTM D 1785; ASTM D 2241; ASTM D 2672; CSA B137.3
Now, C900 by definition meets the AWWA C900 standard.
ASTM D 1785 is a PVC pipe standard, with no reference to joining methods afaik. So it seems like it should be able to meet that, whether it does as part of the C900 standard, or separately.
ASTM D 2241 is very similar to D1785.
ASTM D 2672 is probably the killer: it's about solvent cement connections, so any gasket-sealed pipe system will naturally not qualify. So by this criteria, C900 is out.
CSA B137.3 addresses PVC pipe & fittings, with various joining methods ("moulded, solvent-cemented, or threaded"), but the language in the summaries I can access does not make it clear if gasketed qualifies.
I'm going to stop there: I think there are other standards for the gasketed joining systems, but as far as I can tell they aren't in the codes yet. I wonder if anyone knows more about this.
thanks!
thanks!
