Ryan Schultz
Does the dimension below need to be 3ft per 403.5.1 Clear Width or would there be some exception here?
No, your not following. I bumped out your wall approx. 18-inches@Builder Bob , 2009 ICC A117.1 is the applicable code in our area.
@mark handler, I guess i'm not following. If you mirror your sketch vertically along the center point of the shower, the clearances would still be accommodated.
This is in a Type B unit, btw.-- not sure that makes a difference.
IMHO Still won't have clearancesMark - I think Ryan is saying that (in his opinion) if the wheelchair were to head straight in (instead of backing in as your illustration shows) that the area needed for the rear wheels would protrude into the room and not require the additional bump out.
