    Dismiss Notice
Combustible vs Non-Combustible material
Discussion in 'Residential Building Codes' started by Rookie Troll, Feb 26, 2020.
  1. Rookie Troll
    Rookie Troll Registered User
    Feb 26, 2020
    1
    0
    I have a commercial range that I am installing in my kitchen.
    The manufacturer requires clearances of 6" from combustible & 0" from non-combustible.
    The adjacent cabinets are wood (combustible) but I want to face that with 1/2" Hardie Board (concrete) which I believe will make the the cabinet ends non-combustible.
    Will this comply with code? Will this make the side of the cabinet non-combustible?
    I don't want any surprises when the inspector comes and I can't find anything in IBC or ASTM.
  2. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    3,241
    465
    See 2012 IMC, section 917.2 & 917.3
  3. cda
    cda Sawhorse
    Oct 19, 2009
    17,566
    1,185
    Welcome,
    I would say yes, and the inspector will more than likely not check,,,,
    But you live there and should be safe.
  4. JPohling
    JPohling Sawhorse
    Aug 16, 2011
    1,123
    139
    How do you address where the cabinet returns that are within the 6" dimension from the range. This would be unprotected and I would expect the non combustibles construction would need to extend to a point 6" beyond. Does this commercial range have a pilot light?
  5. cda
    cda Sawhorse
    Oct 19, 2009
    17,566
    1,185
    The residential I installed only showed clearance to the sides/ cabinets
  6. Keystone
    Keystone Registered User
    Feb 23, 2010
    884
    117
    Are you installing a commercial unit in a residential dwelling, if that is the intention it is prohibited by code?
  7. cda
    cda Sawhorse
    Oct 19, 2009
    17,566
    1,185
    It only looks like a commercial stove.
    There are cooking appliances on the market that have size and features of commercial appliances, but they are listed for residential installation.
    Any inspector turn down a specific stove in a house??
    #8 cda, Feb 26, 2020
  8. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,601
    871
    Will this comply with code? NO
    Florida Mechanical Code 2017
    917.2 Domestic appliances
    Cooking appliances installed within dwelling units and within areas where domestic cooking operations occur shall be listed and labeled as household -type appliances for domestic use.
    Not Commercial
    ADAguy likes this.
  9. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,015
    1,027
    Covering something with something else only makes the first thing covered.....It does not make it something it is not....And what the other folks posted for code sections...
    tmurray likes this.
  10. cda
    cda Sawhorse
    Oct 19, 2009
    17,566
    1,185
    Can you please restate the question/answer
  11. Pcinspector1
    Oct 28, 2009
    3,241
    465
    cda, I think steveray is saying: Your putting lipstick on a pig. [​IMG]
    ADAguy likes this.
  12. cda
    cda Sawhorse
    Oct 19, 2009
    17,566
    1,185
    If you are required clearance to combustible surface or zero to noncombustible
    You can’t put a noncombustible material over say wood, that will not transmit heat to the combustible material ??
    And meet code?
  13. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,390
    419
    Only if it is tested/labeled to do so.
  14. mark handler
    Oct 25, 2009
    10,601
    871
    If you could put in a commercial cooktop, you would need a commercial hood with an ANSUL fire suppression system per commercial cooktop listings.
  15. Keystone
    Feb 23, 2010
    884
    117
    The reason I made my comment was based off not the appearance of the stove, JENNAIR makes commercial appearing ranges, but rather the OP’s initial statement of “I have a commercial range......”.
    cda likes this.
  16. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    647
    191
    Concrete board is a great heat transmitter. So yes it will transmit heat to the combustible cabinets.
  17. mark handler
    Oct 25, 2009
    10,601
    871
    You are correct Mike
    HardieBacker Cement Board is deemed noncombustible when tested to ASTM E 136. Even though it will not ignite when exposed to heat, the heat will transfer readily through it and the substrate could ignite with a strong heat source..
    Other cementious products are the same.
    my250r11 likes this.
  18. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    1,219
    203
    Also consider the wall framing behind the range. I specify metal studs behind commercial ranges.
    ADAguy, my250r11 and tmurray like this.
  19. Inspector Gadget
    Inspector Gadget Registered User
    Mar 5, 2020
    5
    0
    Question: does the manufacturer require 6" clearance from combustible *surfaces* or combustible *material?* I think this is what others have suggested.
    I'm a Canuck, so my Codes ain't your Codes.
Share This Page
