fatboy
Administrator
Thanks for the update!
I knew I was going to get all kinds of responses on how crazy this code may sound. So I got some clarification from a fellow contractor who went to the building department last week. I was wrong on my original post and the actual code states that if the floor joist are less then a "true 2x8" then that is when this sheetrocking is to be enforced. So a 2x8 this is actually 1.5 x 7.5 would be required to sheetrock the crawlspace. An inspector told me what some contractors are doing is building an encloser around the furnace that is sheetrocked, so that seems to satisfy the code.
As ridiculous as this sounds, I will find out soon because today I just finished installing a furnace and ductwork in a crawlspace that has floor joist that are 7.5". But on my proposal, I stated I was not responsible if sheetrocking was required on this job, that the general contractor would have to do it. Will find out soon when I schedule my inspection.'
Thanks for reading
2. Floor assemblies located directly over a crawl space not intended for storage or fuel-fired appliances.
3. Portions of floor assemblies can be unprotected when complying with the following:
3.1. The aggregate area of the unprotected portionsshall not exceed 80 square feet per story
3.2. Fire blocking in accordance with Section R302.11.1 shall be installed along the perimeter of the unprotected portion to separate the unprotected portion from the remainder of the floor assembly.
for discussion: if a person created a small crawl space Mechanical room with studs and gypsum around the equipment (w/ proper service/clearance space) would it then meet the fire blocking exception? And then possible having the rest of the i joist or less than 2x10 floor systems area over the crawl space be unprotected.
