They works with my insurance, so when my house got the incident, my insurance company sent them to my house. I did sign some paperwork to let them work on my house to mitigate the water issue.If you do not have a contract with the contractor, who do they have a contract with? If the insurance company tell the insurance company, they need to fix it and need to provide an engineer's report and obtain a building permit for the repair.
There is a common problem with some contractors, often plumbers, that like to use chain saws and sawzall's without regards to the structural considerations.
This is a serious problem and should be addressed promptly.
While a building inspector should appreciate that there is a problem any fix will require an engineer.
Sorry did not get what you meant? can you elaborate more?They didn't learn after the first one?
I’m sorry, your English is a problem, i can’t understand some important parts. What are you trying to say here …PuroClean owner seems to be resistant to say they will do the fix by mentioning that he is a General contractor for 30 years. I would want to hear your opinions on how to talk to this guy to have them hire a proper contractor to do the fix instead of let them do it by himself. Obviously, he tried his best to tell that the issue is minor, he even mentioned that the issue could be fixed with some wood glue or filler.
Sorry for my English here. There was someone from Boise cascade(BC) visiting and taking the measurements on Monday. I'm waiting for a report from BC. What I meant there is that PuroClean wanted to fix the issue by themselves by claiming that he is a General contractor for 30 years. However, for me as a homeowner, it's hard to rely on their service and trust them to do the fix and not causing another problem. There is a conflict of interest here. What your thoughts here? would that make sense to ask PuroClean to hire someone else to fix it?I’m sorry, your English is a problem, i can’t understand some important parts. What are you trying to say here …
The fact that he mentioned wood glue and filler clearly demonstrates that he is not competent. Have you heard back from boise cascade? Is an engineer going to be visiting, or is that the BC guy?
Definitely. Other than allowing puroclean to take pictures, i would not let them back in the house.would that make sense to ask PuroClean to hire someone else to fix it?
That is what you need to have in your hand before anybody attempts to "fix" the damageCurrently, from @Joe.B contact, BC company sent someone to measure the cuts and they will run analysis software to produce a proposed fix.
Some people's skulls are thicker than the I-joist!!They didn't learn after the first one?
Ntas … what’s happening?Hi, I have a drywall on the ceiling of my garage removed by PuroClean,
This is closer to "fell off a cliff"This was untrained unskilled and not thinking labor with inadequate and negligent supervision. I'm a designer and pretty active DIYer, and I would never make that kind of stupid mistake. And if I did - even if just 1 joist - I'd have a temporary support in there ASAP and block entry to floor above and below until supported. I'm happy to be retired partly because of 40 years of designing and seeing the construction, the quality have all gone down hill a lot.
Rant over.
My response is "Well you have doing it wrong for 30 years""I've been doing this for 30 years".
