I think the seating has to be on the accessible aisle...... reasoning, you don't make people travel down an accessible route then interrupt the path of travel with non-accessible features. Item # 3 seems to nail it on the head.ADA website
III-4.4600 Seating in assembly areas. Public accommodations are required to remove barriers to physical access in assembly areas such as theaters, lecture halls, and conference rooms with fixed seating.
If it is readily achievable to do so, public accommodations that operate places of assembly must locate seating for individuals who use wheelchairs so that it --
1) Is dispersed throughout the seating area;
2) Provides lines of sight and choices of admission prices comparable to those offered to the general public;
3) Adjoins an accessible route for emergency egress; and
4) Permits people who use wheelchairs to sit with their friends or family.
If it is not readily achievable for auditoriums or theaters to remove seats to allow individuals who use wheelchairs to sit next to accompanying family members or friends, the public accommodation may meet its obligation by providing portable chairs or other means to allow the accompanying individuals to sit with the persons who use wheelchairs. Portable chairs or other means must be provided only when it is readily achievable to do so.
How many seating locations for persons who use wheelchairs must be provided? Under the general principles applicable to barrier removal in existing facilities, a public accommodation is never required to provide greater access than it would be required to provide under the alterations provisions of the ADAAG.
Must the seating locations be dispersed? The ADA accessibility standard for alterations requires wheelchair seating to be dispersed (i.e. , provided in more than one location) only in assembly areas with fixed seating for more than 300 people. Because the requirements for making existing facilities accessible never exceed the ADAAG standard for alterations, public accommodations engaged in barrier removal are not required to disperse wheelchair seating in assembly areas with 300 or fewer seats, or in any case where it is technically infeasible.
Must a public accommodation permit a person who uses a wheelchair to leave his or her wheelchair and view the performance or program from a stationary seat? Yes. And in order to facilitate seating of wheelchair users who wish to transfer to existing seating when fixed seating is provided, a public accommodation must provide, to the extent readily achievable, a reasonable number of seats with removable aisle-side armrests. Many persons who use wheelchairs are able to transfer to fixed seating with this relatively minor modification. This solution avoids the potential safety hazard created by the use of portable chairs, and it also fosters integration. In situations when a person who uses a wheelchair transfers to existing seating, the public accommodation may provide assistance in handling the wheelchair of the patron with the disability.
May a public accommodation charge a wheelchair user a higher fee to compensate for the extra space required to accommodate a wheelchair or for storing or retrieving a wheelchair? No. People with disabilities may not be subjected to additional charges related to their use of a wheelchair. In fact, to the extent readily achievable, wheelchair seating should provide a choice of admission prices and lines of sight comparable to those for members of the general public.
