- State or Country
- California
- Owner - Contractor - Design Professional
- Other
We plan to install a new fence around our backyard. Is a building permit required for fencing projects?
I agree. Even though "exempt" in the building code, many jurisdictions require it through the muni and Zoning codes.Depends on jurisdiction and rules/regulations. Call the AHJ first.
If the fence is a block wall
5 foot 6 inches above grade do this require permit?
I the 5 foot 6 inch wall has a footing 2 feet below grade, balanced fill on both side does it require a permit?
[A] 105.2 Work exempt from permit. Exemptions from
permit requirements of this code shall not be deemed to grant
authorization for any work to be done in any manner in violation
of the provisions of this code or any other laws or
ordinances of this jurisdiction. Permits shall not be required
for the following:
Building:
1. One-story detached accessory structures used as
tool and storage sheds, playhouses and similar uses,
provided that the floor area is not greater than 120
square feet (11 m2).
2. Fences not over 7 feet (2134 mm) high.
No permit required.
If the fill on both sides is balanced, it's not a retaining wall, so item #4 under the work exempt from permit does not apply.
A lot of things in play here: Others have said check with the AHJ.I agree, permits depend on the AHJ.We plan to install a new fence around our backyard. Is a building permit required for fencing projects?
"... can we build a berm and put a 6ft fence on top of it so we can block our neighbors view?...."A lot of things in play here: Others have said check with the AHJ.I agree, permits depend on the AHJ.
We get questions like can we build a berm and put a 6ft fence on top of it so we can block our neighbors view?
We have open fencing in the front yard and height requirements in our zoning and subdivision rules
HOA should be the first place to check, I live in one that only allows 48" high gothic pickets.
Some city will not allow a fence to block backyard utilities.
What happens when there's a manhole at the property line?
Do you allow razor wire or chicken wire?
Color and type of fence comes up from time to time.
Some may require survey.
ISPSC if adopted has requirements for barriers and some AHJ may have additions to that like inside locking hardware.
Check with HOA and AHJ is the right call.
Then its not a fence. Its a wall.If the fence is a block wall
I see a stone wall.
The ancient tradition of stone fences dates back nearly 4,000 years when stone walls extended over five square miles in the Ceide Fields of County Mayo. However, most of the fences date to the 1840s when land was redistributed and the stone walls defined the field and helped to clear the land at the same time.
I guess I'm wrong again.
FenceFirst person that says we need a definition for fence gets banned......
Never Mark....you didn't say we need a definition.....I know a fence when I see one....Fence
a. : a barrier intended to prevent escape or intrusion or to mark a boundary. especially : such a barrier made of posts and wire or boards. b. : an immaterial barrier or boundary line.
Fence Definition & Meaning - Merriam-Webster
Merriam-Webster
https://www.merriam-webster.com › dictionary › fence
wall
a continuous vertical brick or stone structure that encloses or divides an area of land.
"a garden wall"
BAN ME
Can a wall be a fence.... IMHO, Yes, a wall can be used as a fence...
Since the original post states CAI think you just need to find the best definition of a fence and picket.
