my250r11
More than likely, yesSo in a highrise building like this, the hallway stairs and elevator would constitute as 2 exits?
Elevator, no... but I'd bet that you have two stairway shafts.So in a highrise building like this, the hallway stairs and elevator would constitute as 2 exits?
Dali, I would suggest that you listen to the folks round here, and not the previous contractor who thinks that it was on the HOA to pull the permit. Sounds like this contractor is a real winner and perhaps not the best source for information on how you should proceed.
Hi,
I purchased a condo in a commercial building (half condo, half hotel) in Miami about a year ago. The previous owner ended up converting the unit into a 2-bedroom, and in this building owners just need to submit an application to the HOA for construction approval, and then it's up to the owner/GC to pull the city permits. However, I come to find out after doing a permit search that the previous owner didn't pull any city permits for the work done.
Fast forward to today, the building allows short-term rentals (e.g. Airbnb) but due to Covid they are now enforcing all owners to provide all the documentation that the city of Miami requires to allow short-term rentals, and one of the things they need is a "change of use" to show the unit listed as a "condo-hotel". This is where I run into an issue after reaching out to different architects/contractors that provide a "legalization" services to bring the unit up to code and also a "change of use" to show "condo-hotel".
In one of the proposals I received, they want to provide demolition services to bring the unit back to the original layout and state the reason is because the bedroom doesn't have direct access to the exterior (EERO? R310?). I obviously do not want to remove this extra room, so my question is, would I be able to bring my unit up to code by labeling this room as a "multi-use room (e.g. office, den)"?
Below are screenshot image links of the original and upgraded floor plans of the unit.
Original Floor Plan: https://gyazo.com/0b3c42b72cac0f73bb57dd7e3bb878e1
Upgraded Floor Plan:![]()
Gyazo
gyazo.com
Thank you!
Big can of worms. Here the State might bring charges on the contractor for working with out a permit.
As said talk to local AHJ to see if it can be inspected with only partial demo.
Good Luck.
I just talked to the previous contractor and he kept on telling me that the HOA manager didn't require city permits and they approved the work at the building. I was like what does that matter , you're a licensed contractor and any work you do needs a city permit pulled.
He said it was my issue with the previous owner and not him, and that I should have looked into this before purchasing the unit. In hindsight, I guess it's partly my fault for not doing more due diligence when purchasing this condo but since the seller wrote permits where pulled on the seller's disclosure I didn't follow through doing my own permit search with the city at that time.
Yeah, hopefully after talking to a AHJ I can get more clarity.
Be kind and inform us of the outcome of that. Don't leave us hanging.
Seems to me the contractor doesn't care about permits. Not sure he would be my choice of info. Each Building Official has their own way of dealing with these issues. Some are stiff and some will meet in the middle and some will leave it be. Seen it go all ways depending on the situation and even what mood the BO is in. Thus why I said good luck.
I can't speak for your specific situation, but some facility owners may have an annual permit with the local jurisdiction to cover the many renovations that a large facility may undergo within a year's timeframe. Each jurisdiction with this type of program will likely have its own policies and procedures. Sometimes, self-certification is all that is needed with notification to the AHJ for inspection. More complex projects may require an on-site plan review or a more in-depth plan review if deemed necessary.
You may want to at least verify if the jurisdiction does have a similar program and if the HOA is part of that program. If there is no program or the HOA is not part of the program, then all previous comments apply. If there is a program and the HOA is a part of it, then you need to determine if the HOA complied with the program's procedures. If they didn't, then the HOA could be found in violation.
The seller probably has a document that you signed stating that you did in fact research building dept. records on your own. Realtors have that as standard procedure because they do not research the records and do not want to know the truth. If they do not know the truth they can't be faulted for not telling you the truth.
The contractor is a either a liar or stupid and most likely a stupid liar. The seller stated that permits were obtained and he can claim that he based that on the fact that he hired a licensed contractor....and you know the rest of that story.
Ok, ty...so since this room only has a single exit; then I most likely will never be able to bring this current layout up to code?
Yes, the HOA has some construction package form that owners fill out and as long as this gets approved they allow work to be done in the building. However, they say that then it's the responsibility of the owner/GC to pull appropriate city permits, which this previous owner did not.
Yes, it was already upgraded when I purchased it in November '19; however, I was just looking at the seller's disclosure and I noticed that
it looks like he accidentally skipped 4.b. but the good thing I see is he marked 4.c. with NO which is clearly not the case because I know for a fact that he's the one that upgraded the unit because I have a copy of the HOA construction approval he had to request.
https://gyazo.com/5340b0ef00e37ddd124eddeaab55f77e
What does this exactly mean? Is there anything that I can do at this point for the seller to bring the updates he made up to code? I think it might be too late at this point since I closed on this property back in Nov. '19.
Less then a year, statuate of limitations? Your realtor had a duty to inform you, no? Did you have an inspection report done?
Yes, definitelyhopefully this goes smoothly.
Oh ok, thank you for bringing this point up; I'll look into this as well.
I did the permit search after I closed on the property, but you're probably right; you sign so many documents during the close I'm sure there is something in there that I did already do the permit search during attorney review.
Hahaha...yeah, I'm sure there will be a lot of finger pointing going on between those two! Lol.
Did you say that this is in Manhatten?
DO You even know if the city comes out and does an intial or any inspection of a "" "condo-hotel". """?????????????????????????????
I'm not sure, I guess I would need to ask around; maybe someone at the HOA would know.
So maybe a little worry for nothing???
Find out
City may just want a piece of paper filled out and money in their pockets.
Call the city or should be online
Do you want to say which city it is
