lpiburn
Silver Member
Hello all,This photo is from a current project with a 2nd floor mechanical "mezzanine". There is a floor hatch for normal maintenance access provided elsewhere. The Owner requested this additional opening to accommodate replacement parts etc. It would be accessed via scissor lift.
The original plan was for this to be a 3'x4' access panel, not a real door. The contractor decided to install a regular door anyway (long story). We are planning on rejecting this because someone working in the mezzanine could open the door and fall 14' to the room below. However, I'm really not sure if there are any specific code sections to back us up.This is strictly maintenance only, not an egress door, not accessible by any means. So essentially all of chapter 10 and 11 should not apply. Even so, it just seems patently unsafe to have a full-size door opening onto nothing! Do you think it would suffice to have a big warning sign on the inside saying "DANGER, FALL HAZARD" or something along those lines?I look forward to hearing your opinions on this one.-LPView attachment 2006
/monthly_2013_11/572953ef5ac9d_mezzaninedoor.jpg.158e225f204d685349432142e8e50e61.jpg
