SMiles
I am not able to locate any design requirements for "Draft Curtains" as it relates to IBC 2015 section 1019.3 Exit Access Stairways and Ramps, as mentioned in exception 4. Furthermore it seems a lot of references interchangeably use "Smoke Barrier" and "Draft Curtain" which does not seem correct base on the definition in IBC. I am specifically looking for height/offset requirements from ceiling for a draft curtain. Any information would be helpful.
Thank you - SM
Thank you - SM
