Accepted engineering practice may sound nice but it does not provide the specificity that we expect of our laws.
The laws regulating when an engineer is required are separate from those laws related to building codes. The entity adopting the building code, at least in California, does not have the authority to regulate the practice of engineering. Thus the building code should not be the place to define when an engineer is required
The building departments obligation is to do a plan review It is left to their discretion of how long they spend. Something is wrong with a building department that ignores their obligation because they do not schedule enough time.
It is a mistake to expect the inspector to provide the rest of the plan checking. The inspector's job is to verify that the constructed work complies with the permit documents not to plan check the project.
If the construction documents do not define nail size and spacing I would expect to see a plan check comment. You need to be explicit and not rely on the contractor to know what is required. It seems that in some jurisdictions. people have adopted some bad habits.
The process is in 2 stages Plan Review and Field Inspection.
The general question was an effort to look at how much info is on Plan for both looks
I used 2 examples 1. Accepted Practice as per Masonry Institute and
2. Nailing req,d for Wind Bracing, to make the point
Although the Code captures some of those requirements It would be impossible to capture All That Industry Info
So, I believe that a Prudent Designer (remember we just had a post about the non-need for an Engineer using the prescriptive aspect of the Code) Would OR Should
put a Note, or reference to remind the Carpenter to nail it to spec. I am sure they don't carry a copy in their back pocket.
On the Masonry question, I was thinking of expansion joint locations that should be detailed but are usually not
These were used as typical examples
With your last answer, you demonstrated a good grasp of the Case Law.
Is there one that addresses this situation to give us guidance other than our personal judgment?
We should not rely on Governmental Immunity
