Existing storage building privately owned in LA - Is it required ADA upgraded ?
TDarch
There is an old building that has been used to store landscaping equipment. It recently caught on fire and we were hired to fixed it. It has one restroom inside that was used by the employee of the landscape company. Do the bathroom and access to the building need accessible upgraded?
Companies are always on the hook for ADA compliance for their employees. Even if the building had not burned, it would have required "readily achievable barrier removal." This would not be a building department requirement, but would be part of an ongoing obligation under U.S. civil rights law (don't expose yourself to a lawsuit).
But if your question is: "will the building department require accessibility upgrades as part of the fire repair work?", then the answer lies in CBC 11B, andit mainly relates to:
(1) whether you are just trying to get it back to its pre-fire conditions, or whether you are altering (11B-202.2) or adding (11B-202.3) to the building.
(2) If you are not altering or adding, but are only doing fire repair, does it meet the definition of "structural repair"?
(3) If the answer to #2 is "yes" then see 11B-202.4, which requires the following components to be made accessible, with some exceptions:
11B-202.4 Path of Travel Requirements in Alterations, Additions and Structural Repairs
When alterations or additions are made to existing buildings or facilities, an accessible path of travel to the specific area of alteration or addition shall be provided. The primary accessible path of travel shall include:
  1. A primary entrance to the building or facility,
  2. Toilet and bathing facilities serving the area,
  3. Drinking fountains serving the area,
  4. Public telephones serving the area, and
  5. Signs.
(4) The code section cited above has an exception #8 based on the cost of the project:
11B-202.4 exc. #8: When the adjusted construction cost, as defined, is less than or equal to the current valuation threshold, as defined, the cost of compliance with Section 11B-202.4 shall be limited to 20 percent of the adjusted construction cost of alterations, structural repairs or additions. When the cost of full compliance with Section 11B-202.4 would exceed 20 percent, compliance shall be provided to the greatest extent possible without exceeding 20 percent.
  1. An accessible entrance;
  2. An accessible route to the altered area;
  3. At least one accessible restroom for each sex or one accessible unisex (single-user or family) restroom;
  4. Accessible telephones;
  5. Accessible drinking fountains; and
  6. When possible, additional accessible elements such as parking, signs, storage and alarms.
  5. Signs.
That would be the long answer ;)
