beach
Try contracting out plan checks....... architects, contractors, homeowners, etc. really start to appreciate the "Non-contract" government employee.
The attitude of tear out the work is used to show who is in charge. If you want to be a thug, you can be one. There are other less costly ways to show compliance.RJJ said:George: It is not so much who is in charge. It comes down to doing a job correctly and that includes inspections. Just one of the little details sometimes ignored by contractors. If it is left unchallenged then it will just continue and we are left with no order in the process. Having inspections with plans on site is not something new. This is just a case of I will do as I please.
I am not employed by the contractor so there is no need for me to provide a letter.beach said:George,
As an engineer, would you provide an approval letter stamped and signed by you for those footings?
This is the a thing to be determined, and it sounds like a determination is made. What are you going to do about it?RJJ said:This is just a case of I will do as I please.
If you were employed by the contractor, what would it take for you as an engineer to determine the footings were sufficient and provide a stamped letter stating so?If I were employed by the contractor, I would be in the position to determine if the footings were sufficient. I could provide a letter regarding the sufficiency if asked.
I did not say an engineer was required. My engineering opinion is that a lot of fuss is being made about a non-issue. But non-issues seem to drive a lot of people.beach said:If you were employed by the contractor, what would it take for you as an engineer to determine the footings were sufficient and provide a stamped letter stating so?Would you need to verify steel placement, lap splices, depth/width, soil bearing, etc.? If so, how would you accomplish that?
Or, would you provide a stamped letter stating that, to the best of your knowledge, the footing, steel, etc. were installed per plan/code without actually being able to verify it and hope for the best?
My point is how does an engineer know more about how the footings and steel were installed after the fact any more than an inspector would...... I don't think I'd accept a stamped letter from an engineer unless I knew how he verified it, then.... why would you need an engineer?
Don't mean to make light of your situation. I took a job as an inspector many years ago. My first inspection was a simple framing inspection which I declined to approve as it was just not ready. I left my card asking the builder to call me. Before I got back to the office he was raging on the phone demanding that I return to the job site. Came to find out that that was the first time in eleven years that that department had failed to approve anything it was asked to look at.:roll:Uncle Bob said:North Star,Thanks, I solved the problem. Will be back home for Thanksgiving.
Uncle Bob
I only do work for existing clients and new clients who are referred to me by people I trust. There is no need for a letter.beach said:George, Maybe I'm not being clear.... If a contractor contacted you, an engineer, because he needs to satisfy the building dept. so he can continue working, and wanted to hire you to provide a stamped letter stating that, in your opinion, the foundation is acceptable. Being that, in your opinion, it is a "non-issue" do you provide the letter and if you do, do you actually verify that the foundation matches the approved plans?
