Improving!
You pull a trailer with it yet? Thinking of going that way with an 12 model if things work out.jar546 said:Yes on the ecoboost. The reason I bought it. My 2006 had the 5.4 Triton engine with similar gas mileage to yours.
Wow, good engine. My beater is a '80 Dodge W150 4x4 360 CID posi front and rear, 504,000 miles, 4 engines ( 2 were "emergency" engines on the road), back on the original for the past ~200k, Edelbrock 4bbl and towing cam. Aside from the odd stuck car it has been hooked to concrete trucks, building supply trucks, a stuck semi, multiple trees and a couple of buildings that are no more. 7-10 mpg, it'll hit 12 in the flatland. Daily drivers are a Ranger and a CRV. The one in the barn is a '35 Dodge 1/2 ton, going to switch the flattie to one of those newfangled overhead valve things. Not expecting great mileage but it should be able to really get lost.pwood said:wood/work truck, 1969 GMC i/2 ton 350 v8 with 480,000 miles . original motor and i've had it since 1973. smokes like a tire fire and gets 6-8 mpg. other truck '03 nissan frontier 4x4 v6 4 door with 230,000 miles. oil changes and timing belts and 1 battery so far.
