Go ahead. Tear it apart.
mtlogcabin said:
Now if the P & T drain terminates into the pan that does not meet code. Hard to tell by the picture
I blew it up and it clearly drains under the house. Same as the smitty pan.
Like a pack of rabid ferrets you guys.
I put valves hot and cold as a practice. You can't see the cold shutoff.
Both drains daylight from there and are turned down. Gas shutoff is there.
Water in the pan is from a miscommunication "incident" with my helper. I got wet.
Be still your little hearts, I cleaned up and mopped.
Brent.
mtlogcabin said:
I thought you did a bang up job for a framer :grin:
Well now he is a Jill of all trades.
pete_t said:
Here's a nitpick for you:Watts
http://www.watts.com/pages/support/tp.asp?catId=64
Water Safety & Flow Control Support - Helpful Tools and Resources
"… Excessive length over 30' (9.14m), or use of more than four elbows or reducing discharge line size will cause a restriction and reduce the discharge capacity of the valve. …"
Oh no........not that....after he burnt the wall and all.
I'm a cat person so here's my screen saver. But now that you mention it Brent, there's not a lot of difference. We could ask your helper about that.
Don't you have someplace you need to be?
Brent.
If MASSDRIVER did the job then it is 100% perfect no matter how ****ty or non-code compliant it really is. After all……..it works doesn't it?
Finally. Someone who understands.
Brent.
mtlogcabin said:
Don't blame us because you haven' been complying with the code :p I thought you did a bang up job for a framer :grin:
Still wondering how he gets the solder to melt with his Estwing......Must have to hit it really hard to generate that much heat...
mtlogcabin said:
FYIUPC does not allow it to terminate under the house.
I'm pretty sure that Brent knows that. ;)
I just look at and think about the Seahawks last play call.
It melts.
Brent.
I replaced my gas water heater recently. The second since I have lived in my house. This time, I put the manual gas shut off between the gas pipe and the flex hose. But I did not put any shut off valves between the water flex hoses and the water pipe. I don't know why, I have 1/2 wog valves in the van. I did have to dig more of the dirt floor out because this water heater is taller than the previous heater. And I put some concrete blocks on the dirt this time. If I make it another 20 years, maybe I will do it right at that time.
Tough crowd. I am so glad I did not post any pictures!
mtlogcabin said:
So is it in the crawls space?Come on man up and post some pictures :p.
No, it is in the non-crawl space. But in 1890, cellars did have dirt floors. Unless they put pieces of left over wood flooring on top of the dirt.
