help with plans needed
That's curious, any idea why? I've never seen anything prohibiting monolithic pours. Is that due to cold (frost heaves?) more than seismic maybe?
FROST HEAVES? Now thats a term from the past---I havent heard that since I moved to massachusetts in 1984 for college.
In my 35 years of doing residential work, I have never been asked by a plans examiner to provide plumbing isometrics. Commercial....yes, residential no. Am I alone on this? I do provide comprehensive specs. and drawings. What do others do for residental permit plumbing drawings?
mine is. absolutely.
If you decide to do the drawings yourself, take a look in the back of the International Residential Code, Appendix N, there are some pretty sophisitcated sample bathroom groups etc that could help you with the drawings.
Its City of Anchorage, Alaska requirement, never seen that anywhere else but its due to seismic. Anchorage is on a swamp of sediment. My property now is on the kenai Peninsula south 150 miles is on great SP/SW sandy gravel soils. When i did build up there, they wouldnt let me pour monolithic. I their mind I think it might of had to do with the "seismic hooks" you have to install I am really not sure, I thought it was stupid seemed to me I could still pour monolithic. They make you build these hooks that extend from the footing up to a few inches down from the top of the stem wall, or you can use galvanized "all thread." Then my home designer over engineered everything above the Muni, that place was a nightmare I ended up subing out a lot of the house construction.
for what its worth- the place I went to for duplication/scanning/copies/printing- and they specialize in printing plans and so on for builders---said that the city I am in and another are the 2 most demanding cities in the state. Just my luck.
But they require a FULL set of plans---including a list of all the plumbing items necessary. Thank you all.
Frost heaving does happen up here if you dont extend your footing below frost line if you are in a moisture susceptible soil. Never heard of this with slabs. This also goes for some of our Canada friends on here.
The duplex I am building now I got enough concrete and rebar to build a mini bridge. Plus have great soils for compaction and are not moisture prone. I was not able to backfill before it froze but it is not going anywhere.
I built a 24x36 cabin back in the day and was not below the frost line. I got rid of topsoil down to gravel and brought in some good pit run. Sold it 5 years ago but went by there a few months ago and talked with the owner, foundation solid as a rock. He even added an attached garage.
If you are on good gravel or sandy soils not prone to holding moisture, if you have enough rebar and solid footing I really dont have the frost heave scare.
Duplex I am building now I am going way above and beyond but it will be worth 450-500k when done for 170-200k investment. Doing most the work myself. Thanks to these forums they can hold hands with guys like me.
Crazy, I would have thought that a monolithic slab would be stronger, but I'm no engineer.
