Good call, if it's a grocery store there is usually a fire truck there anyway.Jake said:Inline with an accessible parking space access aisle is a good place...shouldn't be blocked normally.
Parked in the fire laneconarb said:Good call, if it's a grocery store there is usually a fire truck there anyway.
hlfireinspector said:Parked in the fire lane[/quoteIs not the purpose of the fire lane fire truck parking?
Is not the purpose of the fire lane fire truck parking?Frank said:hlfireinspector said:Parked in the fire lane
I don't recall any such requirement. Good idea, absolutely. FDC is supposed to be plainly visible, or have them put a "FDC" sign with an arrow under the strobe, if it's not clear.Pcinspector1 said:Got the strobe above the FDC now, which bring up another question, the strobe is on the same wall but relocating the FDC 25' down the same wall. Will the strobe need to be relocated as well? it's on the same wall.
pc1
Anyone of the below will work...Pcinspector1 said:Does the nfpa13 determine where the Fire Department Connection shoud be on a building? I can't fine anything I know it has to be a minimum 36" above grade but where should the connection be? Is up to the BO of FD?Pc1
