Builder Bob
Work area is not defined by the actual wall that is depicted. The work area is the area needed to perform the work .......for example a plan depicts a wall of 16 feet in height..... the wall will have gypsum placed on both sides for full height.
The workers don't stay in the four inch width of the wall to perform work. Are they using scissor lifts, ladders, scaffolding, what?
New HVAC system - How is the duct work going to be installed? Does it magically appear in the open web trusses overhead? Does it float up their and attach itself as required by the codes for support?
Folks,
Common sense should apply........ And be realistic. As the interpretations rendered by ICC always state - this is their interpretation and it may differ than the AHJ at the local level.
As a plan reviewer in the past, I would often call the contractor and ask him/her to realistically tell me how much room or area they needed to perform the work. That defined the work area...... If the contractors work area was smaller than what the designer stated, I always took the most restrictive approach to maximize the SAFETY of the public that we are suppose to serve and protect.
Folks,
