insulation
Oh Well
We require that a goodly amount of water pipe be insulated.
The insulation on the right is a tight fit. The contractor used the insulation on the left which is loose. An inspector wrote a correction to replace the loose insulation with the tight fit insulation. I'm not the guy for insulation code and this other inspector is a plumbing guru whereas I'm lucky if I hit the bowl.
So what do you guys think about this? Was it worth making them do it over. My first reaction was..... Hey now, the tight insulation has a thermal bridge and the loose insulation barely touches the pipe. Honestly, I would have never noticed.
It is a workmanship issue. I suppose you could really step into it and get the insulation manufacturer involved to ask the question, "does this product, as installed, provide for R3 insulating properties on the pipe? (R3 is just an example requirement.)
Washington State requires R-3 pipe insulation for freeze protection. When I contacted the manufacturer asking about the pipe wrap r-value, she replied with:
R value on item 3/4"- #P11X - 2.1 and 1" -P12X - 2.0.
Thank you
Cheryl
Thermwell Products
201-684-4400
Interested in hearing someone tell you, "that is what we always use", ask about the pipe wrap r-value.
I've always thought the insulation was to prevent condensation on the outside of the pipe and would imagine that if the insulation isn't snug to the pipe it wouldn't work for that purpose.
In general, the outside diameter of a copper pipe will be 1/8” bigger than its nominal width. Plastic pipes will be 3/8” bigger, and cast iron pipes will be ¼” bigger. To derive the nominal width, you need to know what the pipe is made of and then subtract the correct amount.
