Mr. Inspector
Doe a ATM require a GFIC?
no.Doe a ATM require a GFIC?
It is all about the definition in the NEC and not what we think.Why? it has no water serving it and the outlet is typically not exposed to weather as at a bank, or indoors at mini-marts and airports
Yes, it is a type of vending machine. See 11B 707
422.2 Definition.
Vending Machine. Any self-service device that dispenses products or merchandise without the necessity of replenishing the device between each vending operation and is designed to require insertion of coin, paper currency, token, card, key, or receipt of payment by other means.
escalate it to a level that will ever affect your job.
IF an ATM is "listed" as a "vending machine" then it has to be GFCI protected. IF an ATM is not "listed" as a "vending machine" then it does not have to be GFCI protected, THEREFORE, the listing gives you the answer you are looking for. Check the listing which is based on the testing..................
I always like to know the "WHY" of things. So why was it decided that vending machines should be on GFCI's?
1. Is it more dangerous to get a drink out of a vending machine than a frig at the convenience store?
2. What makes an appliance more dangerous if you put in money or use a credit card?
3. What makes if more dangerous to get a product out of an appliance?
4. Or is it the combination of putting money in or swiping and getting a product that makes it more dangerous?
5. Why is making a cup of coffee at the local 7-11 more dangerous than a coffee vending machine?
Why? Does anyone here know?
If there was a answer to this when an appliance needs a GFCI would be a lot clearer.
