tmurray
That is a lot or people who don't know how to do their job properly and a whole lot of not-my-jobism.
14 Sprinkler heads exposed to paint/drywall compoundThat is a lot or people who don't know how to do their job properly and a whole lot of not-my-jobism.
There typically isn’t any intumescent caulk with a damper…<sigh>
So I have this job - a fairly simple one. Change ventilation in a public building.
Background
1) Final inspection shows that they ran the duct through a fire separation without a damper.
2) Followup shows they installed a damper, but there's a 3" hole around the damper, with no flanges.
Today, I receive images that they've installed fire-rated drywall and flanges around the damper.....
... except they used a grinder to cut the flange to run conduit past the flange. No fire stopping, either.
<sigh>
<sigh>
Background
<sigh>
They have some out of plane ones…maybe 18”…"<sigh>" indeed.
What you describe is fairly typical. About ten years ago (maybe 12?) this state built a new community college building in the city near me. I was on a project site with one of the state building inspectors. He said his team found over 300 improperly installed fire dampers throughout the building.
We had one a couple of years ago where the HVAC contractor installed the fire damper 3 feet away from the rated wall it was supposed to protect. He said he had no idea the damper had to align with the wall.
Better than drywall screws maybe....Today, I had one of my *favourite* conversations.
Up here in the frozen north, we have a program aimed at providing national mobility to certain trades. It's called "red seal," and basically means "I'm know the regulations, and can work anywhere in the country where a licence is required."
Our jurisdiction has no licencing for contractors. Yet several times a year, someone I've never met tells me, "I'm a red seal carpenter," which means "I know Code, dude."
Had that happen today. Two minutes on the site for a spot inspection, guy tells me "I'm a red seal carpenter,"
This guy had used wood screws for structural framing.
We had a "20-year veteran" working on our building. No idea where the dampers were supposed to go. Then got the wrong ones ("whaddya mean.. this is a horizontal duct, and I got a horizontal damper .... what's wrong with you fellers?."
The last few things I bought and put together had instructions. The instructions didn't have any words. Just pictures. I liked them. What does that say about the instructions? About me? (rhetorical, I know what it says)If all else fails, follow the instructions.![]()
For us, the language is like this:That code section for how to install dampers is waaayyyy to complicated.
IMC 607.2 Installation. Fire dampers, smoke dampers, combination fire/smoke dampers, and ceiling radiation dampers located within air distribution and smoke control systems shall be installed in accordance with the manufacturer's instructions, the dampers' listing, and sections 607.2.1 through 607.2.3.
That's what this guy didThe damper shall be installed in the orientation and airflow direction as indicated on the damper.
You're assuming contractors read something?The thing is the instructions are part of the damper's listing and if they aren't followed it voids the listing. They will say where the damper goes in relation to the assembly, what types of assembly it can be installed in, how to frame the opening in the assembly, and how to attach the damper to the assembly. Unless it listed that way, a damper installed outside of the wall is not installed correctly and in reality a waste of money. Its not protecting anything.
That is an assumption that does not always hold true in the wide world of Listed products. I don’t have firsthand experience with dampers however, I have been exposed to how some NRTLs fail to perform when it comes to installation instructions.The thing is the instructions are part of the damper's listing and if they aren't followed it voids the listing.
Inspector G,
You should have told him!
Your constipated with knowledge.....let it go...grasshopper!![]()
Education is expensive.....It's not the making money, it's the saving.
and there is no teacher like failure.Education is expensive.....
