tbz
SILVER MEMBER
Didn't know if I should post this here or in accessibility section. but here is my question(s). Project is located in California so chapter 11 section 1126A in other states it is covered in the 2010 ADA under section 404.2.4.1, but I posted here because of being in Cali's chapter 11.
- MOE exit stairwells if the door from the floor level is locked out and only allows for people to exit into the stairwell, does not allow reentry to a floor once the door closes, does the code require that door to meet the maneuvering clearance requirement to get back on to the floor which can't be done without someone opening the door.
- Hence if you can't travel back inside by design of normal access, is that door required to still meet the maneuvering clearance requirement, from inside the stair well back in to the floor level?
