And here’s the first thing in Chapter 10:The rear door may not be the designated accessible entrance and it may not be a designated accessible means of egress, but it is there, customers do use it, so it is "a" means of egress. As a component in a means of egress, it is regulated by chapter 10, not chapter 11.
If this is what you are referring to, it has never happened.California is one of those states that allows local building officials to grant modifications from the requirements of the code.
Because it says so doesn't make it so. And a code that allows a single 4" step anywhere fails the "reasonable level of safety" test.First, the building code is, by its own statement, the "minimum requirements to provide a reasonable level of safety,
health and general welfare."
So you open the door and walk in only to discover that the floor isn’t where you thought it was. That door shouldn’t be there.The back door has a 4" step down into the store.
I am working on a small retail store with two entrances/exits but only one is required. The front door is on the accessible route and is ADA compliant. The back door has a 4" step down into the store. We would like to add a ramp but to save space, I'd like to make it smaller than what would be required by ADA. Would this be allowed or advisable? It is in Florida and I know they are strict with ADA.
