    Dismiss Notice
NYC residence "convenience stair"
Discussion in 'Residential Building Codes' started by griffino, Jun 28, 2020.
  1. griffino
    griffino Registered User
    Dec 5, 2019
    15
    2
    I have a client who lives in a 12 story building in NYC. They purchased the unit below theirs and want to cut a hole and combine the two units with a new stair. We will need to comply with the 1968 Building Code of the City of New York https://www1.nyc.gov/assets/buildings/building_code/1968_building_code_v1.pdf.
    My question is whether this stair would need to comply with all the requirements of an Interior Stair under 27-375.
    The definition of "Interior Stair" is "A stair within a building, that serves as a required exit". I do not believe this stair serves as a required exit, as we are not changing the means of egress from each individual floor.
    I see another definition for an "Access Stair - A stair between two floors which does not serve as a required exit." This seems more applicable here, but I don't see access stair requirements outlined elsewhere in the code. I only find that they can be unenclosed and a Spiral Stair can be used as an Access Stair.
    Thanks for the help and if anyone has questions please let me know.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    18,234
    1,294
    Sounds like an access stair.
    But, when are they going to update to a newer code?? 1968???
    Seems like present code would apply?
    Seems like high rise codes might kick in??
    Seems like there may be a problem opening a floor in a high rise?
    Seems like set down with the building Dept, before going to far down the avenue!!
  3. griffino
    Dec 5, 2019
    15
    2
    In NYC you have the option to use the older code for certain aspects of older buildings. Means of Egress is one.
    jeffc likes this.
  4. cda
    cda Sawhorse
    Oct 19, 2009
    18,234
    1,294
    I need to move there,,,
    So I can install an escape slide.
  5. ICE
    ICE Moderator
    8,940
    1,121
    Does what you propose fit within the narrow definition of a Means of Egress?
  6. griffino
    Dec 5, 2019
    15
    2
    My argument is that the new stair is not part of a "Required Exit" and therefore is not part of the Means of Egress system. Therefore it wouldn't need to comply with what the 1968 code calls an "Interior Stairway". The 1968 code does not have a definition for "Means of Egress" but it does have this for "Exit"
    EXIT.- A means of egress from the interior of a building to an open exterior space which is provided by the use of the following, either singly or in combination: exterior door openings, vertical exits, exit passageways, horizontal exits, interior stairs, exterior stairs, fire towers or fire escapes; but not including access stairs, aisles, corridor doors or corridors
    Does that mean I can say its an "access stair"?
  7. griffino
    Dec 5, 2019
    15
    2
    In fact, I'm required not to alter the means of egress by the DOB for the type of permit I'm applying for. I'm also seeing some guidance from the DOB saying you can have an "interior access stair" between apartments. So I think I'm on the right track. Would love if someone with experience here can confirm though!
  8. cda
    cda Sawhorse
    Oct 19, 2009
    18,234
    1,294
    From your research appears
    access stair is approved by code,
    Just check other provisions, since you are in a high rise.
    Most present codes allow an opening between floors, with no added requirements.
  9. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,713
    452
    is the building sprinklered?
  10. griffino
    Dec 5, 2019
    15
    2
    It's not sprinklered
  11. ADAguy
    Sep 11, 2013
    4,713
    452
  12. cda
    cda Sawhorse
    Oct 19, 2009
    18,234
    1,294
    It was built in the 70's
    A lot of high rises with out fire sprinklers, makes sense, doesn't it?
    They burn up, and not down!
  13. griffino
    Dec 5, 2019
    15
    2
    Closer to 1870s... It was built around 1905
  14. khsmith55
    khsmith55 Bronze Member
    Oct 23, 2010
    183
    20
    Even if a "sub-standard" stair is permitted I would be scared to death to design one. The first time someone falls down the stair guess who they are going to come after. When the Attorney asks why you designed a "dangerous" stair are you going to reply, because I could? His next question is going to be didn't you know it was a "dangerous" stair based on current Codes and data? Tread lightly and be carful.
    Ken
    ADAguy likes this.
  15. cda
    cda Sawhorse
    Oct 19, 2009
    18,234
    1,294
    So still trying to figure out how 1968 building code applies??
  16. cda
    cda Sawhorse
    Oct 19, 2009
    18,234
    1,294
    So why is it dangerous ?
  17. griffino
    Dec 5, 2019
    15
    2
    1968 code applies, its not a question
    I understand I can be sued for any number of reasons. I would not tell a client they need an exit stair in their apartment if its common practice to provide a less stringent stair.
  18. ADAguy
    Sep 11, 2013
    4,713
    452
    Floor to floor height, rise and run, handrails, headroom, floor framing are all issues of concern.
  19. griffino
    Dec 5, 2019
    15
    2
    Because floor to floor height is more than 12' (its 12'-9") the stair would require an intermediate landing if its part of means of egress. Client just wants to know if they can get rid of the landing and make the stair 30" wide rather than 36".
  20. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,244
    1,094
    I think you can call it an access stair, that might get you out of the rating, but the landings and other stair requirements might still apply...Not an NY guy...
Share This Page
