Mr. Inspector
If no permit is required there is nothing you can do.
I am sure you are correct considering they are considerable differences in the manufacturing between "fixed" and "open-able" windows.My research has revealed that the window industry doesn't consider an openable window which has been screwed shut to be a "fixed window".
I got the idea that these windows were in a common are and not the apartments.Keystone said:just go and walk thru each unit to verify prior.
Since the windows were located in hallways and stairways, the only question I didn't see answered is the need for Safety Glazing: "Were the window required to be SAFETY GLAZING? And if not, why not?"MikeC said:A local apartment building had .... hallways and stairways had fixed windows....were replaced ....
You are in the wrong section of this forum. You are referring to the IBC or IRC. IPMC is a horse of a different color. It applies to the general maintenance of properties and doesn't have anything to do with permits. Correcting some violations of the IPMC may require a permit and the application of another code. In this case, going from the current openable windows back to fixed windows would require a permit.Rick18071 said:If no permit is required there is nothing you can do.
Agreed they became fixed when screwed shutfw. said:If the owner could have removed the windows entirely and filled in the opening with a wall and not have been in violation of any other codes (light, ventilation, etc.), I don't see an issue with screwing them shut.
They are all reasons that apply to a landlord and enforced under IMPC.Pcinspector1 said:Screwed, nailed, wedged, painted, blocked and covered with plywood would be ok to some, if the glass is broken then we could have a problem?Do you think any of these issues listed are the reason its in the IMPC to keep landlords from not making the needed repairs?
pc1
I would say yesmark handler said:Are storm windows legal on sleeping rooms?
I say noGregg Harris said:I would say yes1026.4 Operational constraints. Emergency escape and rescue openings shall be operational from the inside of the room without the use of keys or tools. Bars, grilles, grates or similar devices are permitted to be placed over emergency escape and rescue openings provided the minimum net clear opening size complies with Section 1026.2 and such devices shall be releasable or removable from the inside without the use of a key, tool or force greater than that which is required for normal operation of the escape and rescue opening. Where such bars, grilles, grates or similar devices are installed in existing buildings, smoke alarms shall be installed in accordance with Sections 907.2.10 regardless of the valuation of the alteration.
Window shutters or storm windows?mark handler said:I say noMost are installed and latched from the outside
o k a y . . .gregg harris said:window shutters or storm windows?Storm windows frames or mounted on the exterior but the operable window can be raised or removed from the inside of the structure.
304.18 Building security. Doors, windows or hatchways for dwelling units, room units or housekeeping units shall be provided with devices designed to provide security for the occupants and property within.
The ones I am familiar with do not open or operate from the inside. I have never seen ones that operate or release from the inside.JBI said:mark, Why wouldn't storm windows be permitted in sleeping rooms? (unless they reduce clear opening below the required dimensions that is)
