steveray
Is that an Air Jordan covered in tar?....He does get green points for recycling....
Well then come out here and deal with the crap I see. After a few weeks of that I think you might develop and eye for what's worth doing over.jar546 said:That is why we continue to see work like that. The inspector's willingness to look past obvious violations. Why is that? Why do inspectors feel entitled to grant passes for the violations that exist? What authority do we have to do that?Our company would tell them to move the panel or the hose bibb and correct the rest of the crap. Do it right or don't do it and let someone who knows what they are doing do it.
Why a second ground rod 6 ft away? And then I suppose the third one is because the second was not placed correctly? Surely a simple hacienda can't need three ground rods. When I build a new out-of-the-ground bank, the electrical plans call for three ground rods 10 ft into the ground spaced 20 ft apart, all tied together and the resistance has to be tested and certified. Sometimes they place them in a triangle, more often they are in a straight line along the back of the building. And then there is a (I think) #4 solid going to the main inside panel. Why do you require the grounding condustor to be in flex? One reason could be that in the event of a short to ground, the ground wire carries all the current so you're trying to prevent someone from coming in contact with a temporarily energized wire. Ok, but it looks like the flex sheathe is bonded to the ground rod, so doesn't it also carry the current?ICE said:One of the corrections was to provide a second ground rod a minimum 6' from the first rod. This time around it says provide a third rod a minimum 6 feet from any rod.
The test can cost upwards of $1000.00. I have never had anyone do that instead of another rod.e hilton said:So is it just easier to install 2 rods than test the first one?
