345_Architect
Thanks for all the responses - Building Dept Supervisor is away for a few days - hopefully get some traction when she is back. I will keep you updated on what transpires.
You do not need to address it. Like many things in the code, if you provide, you must comply. There is nothing that says you Must have a Bathroom group. Or a Bathroom group in the same room.And addressing “bathroom group”
That is why they use sand intercepts.... UPC 1009.0.There has always been exterior showers at public swimming pools! Even at the beach on the board walk, especially with all the sand that comes with it. Can't imagine all that sand going in the sewer system as legal. At best to storm water with sand to follow. Must be a heck of a mess to keep the storm water mains and discharge ponds free of sand.
I suspect that the climate will entertain the idea of an outdoor shower. Barring that, any interior shower as always needs to be sanitation proof, i.e. tile, porcelain, any approved non absorbent material. That was my first thought for the reason why for an interior shower, outside, obviously freeze protection and bleed off valves to winterize, but heck in your location why not, see nothing conclusive that an outdoor shower is prohibited. And whether or not an enclosure of any type would be required, other than for privacy sake.
Based on Architects Location, Cayman Islands, it is probably on a septic system.That is why they use sand intercepts.... UPC 1009.0.
Was responding to Bryant, who is in Virginia, not so much the OP.Based on Architects Location, Cayman Islands, it is probably on a septic system.
I do believe the code in Virginia, is the IPC.Was responding to Bryant, who is in Virginia, not so much the OP..
Yup, left that out of my comment, interceptor. But I suspect that is on the line maintenance folks to keep up and up. I know in VA beach on the board walk there are such showers that are for rinse off, and there is a lot of sand going down in the grating.Was responding to Bryant, who is in Virginia, not so much the OP.
Beyond that, a septic tank works similar to an interceptor. The slow moving water in the reservoir will cause the solids to fall out of suspension. For those with septic tanks, this will mean that regular removal of solids by vac-truck will be important. If non-organic solids are forced into the drain field lines, they will soon become plugged and inoperable.
