Piers capped with 4" solids?
Buelligan
Eastern Panhandle WV
Maybe you guys can help? The IRC appendix for mobile homes states that all piers must be capped with 4" solids. Do you consider putting a 1 1/2" solid under the wood shims to be capped with 4" solid? Should the 1 1/2" be under the 4" solid? Would the concentrated load from the shim be too much for the small block? Thoughts? Thanks guys!
attachment.php
To really inspect a MH setup you need the manufacturers' installation installations. That said half height blocks (4") are used to help adjust for overall height and when used they need to be solid, no hollow 4" blocks and they are the minimum height for cmu blocks. Another method of height adjustment is to use 2x or plywood between the staked blocks.The code section you referenced has "or equivalent" and typically most states that have their own MH programs and manufacturers installation installations allow 2x material or rips of 1-1/8" plywood as cap material just so long as it's the same size as the block.What I would be concerned about in your photo is what appears to be a half width 1 1/2" block. I would not accept the 1-1/2" block full width or not. I would recommend replacing the 1-1/2" block with a 2x material and that has the added benefit of making it easier to adjust the wedges.Excerpt from the HUD's installation standards.
/monthly_2011_07/MHCCInstallationStandardsFinalRule.jpg.2a5f1e9ff41bf2bc1231bc4374b816fc.jpg
The 1 1/2" are likely patio block with little or no compressive strength, that would be my biggest concern.
I don't know where you are, but states often license and permit moving and installation of these dwellings. They usually defer first to manufacturer's specs, but do publish standard instructions as a "default" set. Anchorage and support, utility connections, heating and cooling.
