R-2 Sprinkler System
If the R-2 Classification is correct, then You would not use the IRC. Use IBC and IEBC if adopted.
If you were using IRC, anything outside the prescriptive, you fall back to the IBC.
It is an existing building therefore you should start in the existing building code which may seem confusing when you first look at it but when you understand how it works you will realize you are not looking for "loopholes"
Effective Use of the International Existing Building Code
The International Existing Building Code is a model code in the International Code family of codes intended to provide alternative approaches to remodeling, repair or alteration of existing buildings. A large number of existing buildings and structures do not comply with the current building code requirements for new construction. Although many of these buildings are potentially salvageable, rehabilitation is often cost-prohibitive because compliance with all the requirements for new construction could require extensive changes that go well beyond the value of the building or the original scope of the rehabilitation. At the same time, it is necessary to regulate construction in existing buildings that undergo additions, alterations, renovations, extensive repairs or change of occupancy. Such activity represents an opportunity to ensure that new construction complies with the current building codes and that existing conditions are maintained, at a minimum, to their current level of compliance or are improved as required to meet basic safety levels. To accomplish this objective, and to make the rehabilitation process easier, this code allows for options for controlled departure from full compliance with the International Codes dealing with new construction, while maintaining basic levels for fire prevention, structural and life safety features of the rehabilitated building.
This code provides three main options for a designer in dealing with rehabilitation of existing buildings. These are laid out in Section 301 of this code:
OPTION 1: Work for alteration, repair, change of occupancy, addition or relocation of all existing buildings shall be done in accordance with the Prescriptive Compliance Method given in Chapter 4. It should be noted that this same method is provided in Chapter 34 of the International Building Code.
OPTION 2: Work for alteration, repair, change of occupancy, addition or relocation of all existing buildings shall be done in accordance with the Work Area Compliance Method given in Chapters 5 through 13.
OPTION 3: Work for alteration, repair, change of occupancy, addition or relocation of all existing buildings shall be done in accordance with the Performance Compliance Method given in Chapter 14. It should be noted that this option is also provided in Chapter 34 of the International Building Code.
Use the existing code book to start. It's easiest to use chapter 3 "Prescriptive Compliance Method". If you are changing it from two apartments to 4 apartments it would be "a change of occupancy" from a house (complying to IRC) to R-2 (compiling to IBC). Also you need to use the "Alteration" and "Accessibility for Existing Buildings" sections.
Then anything you build must go by the IBC.
A local AHJ does not have to adopt the IEBC in order for a designer to use it.
It is already referenced in the IBC as an alternate method of compliance
3401.6 Alternative compliance.
Work performed in accordance with the International Existing Building Code shall be deemed to comply with the provisions of this chapter.
If the dwelling units do not share an exit corridor then you still do not have have to sprinkle
The IEBC section 301.1 exception is "another alternative to using the three compliance methods that allows for compliance with the laws in existence at the time the structure was originally built, unless the building has sustained substantial structural damage or is undergoing more than a limited structural alteration. Repairs and alterations in flood hazard areas have additional requirements to the laws in existence at the time the structure was originally built."
Review your state or local administrative provisions to verify if the code official has the authority or power to disallow this exception.
