tbz
Silver Member
Have a client which hired a DP to make the front entry fire egress compliant and ADA. This is a daycare facility / kids pre-school.
The reason for may post and questions you will see in the pic's below, we have been requested to provide a quote and budget for the handrails for this project.
I will start with that the church owns the property, but rents to a tenant who runs a day/care/pre-school not affilitated with the church.
1.) my first question is that the picture of the bottom of the ramp ends at a landing, which requires curbing for roll off protection, the client has elected to continue the handrails along the landing to act as the curbing, but has requested the handrails stop prior to descending down from the landing to the parking lot.
The lower ramp/walkway from the landing to the parking lot exceeds 1:20, is exactly 36.5" wide and does not have a full slope side cut to the parking drain.
Do you see anything wrong with this layout? Are foot feelers required in the concrete here or only on public streets curb cuts? Is this small ramp a curb cut ramp or a traditional ramp requiring handrails?
Next the picture below shows the top of the ramp, but to the right of the ramp are the old handrails which they are not changing, I noted these handrails do not comply with ADA, however it is church property rented out, do the handrails also need to be changed to comply?
I will also take input on any other things you see jumping out at you.
Thanks
Thanks
